Hard Drive Copy/all
Hard Drive Copy/all
Attaching a modified version of Jim Butterfield's Copy/All, which will allow drive numbers from 2 - 9.
This was original included on the Lt. Kernel Hard Drive, by Fiscal Information. However it will also work with CMD Hard Drives.
FCopy, which is included with the CMD Hard Drive utility disks has a hard time with REL files, which Copy/All does not.
HD-CopyAll.d64
(170.75 KiB) Downloaded 311 times
Re: Hard Drive Copy/all
That could definitely be useful...
The other feature I'd love to see in copy-all is a dir listing technique that works with an sd2iec which does not have a .dxx mounted. At present, when I use any of those "view-the-directory-without-loading-it-into-memory" routines, all I get back is an endless series of the number 257 (if memory serves.) It would be very handy to be able to copy "raw" files from the SD card in the SD2IEC onto a real disk / CMD HD / RAMLink / etc. You can see the "raw" files when you do a LOAD"$",8 but not when, for example, you use the F1 key in JiffyDOS.
