AutoDuel (Working with fixes)
The two disk images contain the working version of AutoDuel that I have on my BBS. bbs.catracing.org 6400
I was able to piece together a working version from several different archives floating around the net, and have applied the fixes done by the author Captain Keelhaul available on Commodore Image BBS (cib.dyndns.org 6400).
D1 contains the main installer plus file, the installer files, and the system files.
D2 contains all of the + and -. files needed by the game.
To install.
From disk 1.
Copy the installer plus file and the installer modules to your plus files disk
Copy the s. files to your System Disk
From disk 2
Copy the +. files and the -. files to your PLUS FILES disk.
Run the main +.ad installer file, and follow the instructions.
After the installation you will be prompted if you want to delete the installer files off your drives. This is up to you, it will only affect the files copied to your BBSW, it will not delete them off the original disks.
Enjoy!
AutoDuel_D2.d64
(170.75 KiB) Downloaded 362 times
AutoDuel_D1.d64
(170.75 KiB) Downloaded 361 times
